15 years ago
Quartus Internal Error Advice
When compiling I get the following error in a window. It happens during the Fitting section of compile.
Internal Error: Sub-system: CDB_ATOM, File: /quartus/db/cdb_atom/cdb_atom_sys.cpp, Line: 1338
implements(type)
Processors in use: 4
Stack Trace:
0x6a963: SIN_VALUE_UTILS::get_io_pad + 0x1f3 (TSM_SIN)
0x606a9: Sin_Unload + 0x8bb9 (TSM_SIN)
End-trace
Quartus II Version 9.1 Build 304 01/25/2010 SJ Full Version
Service Pack Installed: 1
I've been getting different errors recently, but this is the first of its kind. I'm trying to set up a pseudo-differential signal on a Stratix III.
Any advice as to where I can find info on this error? I've been looking, but haven't found anything.
    Thanks Jai Shree!! I usually restart Quartus and it works!!
    Most internal errors can be removed by deleting "db and incremental db",try to delete and see if it works.
    unfortunately, most internal errors are hard to debug without Altera's help. i recommend creating a small project that exhibits this problem and attaching it to a Service Request
    note that 9.1 is getting to be a bit old, support may be limited
