15 years ago
quartus_fit switches equivalent for quartus fit QSF commands
Hi all,
I trying to find an equivalents to quartus fit QSF settings commands in quartus_fit switches
For example:
set_global_assignment -name FITTER_EFFORT <"STANDARD FIT" | "FAST FIT" | "AUTO FIT">
has the equivalent
--effort=<standard|fast|auto>
I can find equivalents only for the following four commands:
* set_global_assignment -name FITTER_EFFORT <"STANDARD FIT" | "FAST FIT" | "AUTO FIT">
To
* set_global_assignment -name OPTIMIZE_IOC_REGISTER_PLACEMENT_FOR_TIMING [ON | OFF]
To
--optimize_io_register_for_timing[=on|off]
set_global_assignment -name AUTO_PACKED_REGISTERS_<family> <OFF | NORMAL | "MINIMIZE AREA" | "MINIMIZE AREA WITH CHAINS" | AUTO>
To
--pack_register=<off|normal|minimize_area
|minimize_area_with_chains|auto>
set_global_assignment -name PLACEMENT_EFFORT_MULTIPLIER <value>
To
--inner_num=<value>
There are a lot of Quartus Fit QSF commands which I cannot find equivalent for
For example
set_global_assignment -name WEAK_PULL_UP_RESISTOR [ON | OFF]
set_global_assignment -name AUTO_MERGE_PLLS [ON | OFF]
Can Anyone advice where I can search for equivalents for those QSF quartus fit commands?
Abdelrahman
    Hi all,
    Thank you so much for your answers they are really helpful
    I have another question, I am trying to set Timing optimization to extra effort for Quartus fitter through command line switches so I wrote
    execute_module -tool fit -args {--set=optimize_timing="EXTRA EFFORT"}
    But Quartus fitter errors out with
    Error: Unknown argument "EFFORT". Refer to --help for legal arguments.
    I face same problem with any option which accept values with spaces in between
    Any suggestions?
    It is not recommended to run all your commands from quartus_fit. A few things were added that are commonly used, and really seed is probably the only common one. Everything else should be stored in your .qsf. That being said, two options:
    1) There is a generic --set option that allows you to put in your own values, i.e. .qsf settings directly.
    2) Rather than passing arguments via quartus_fit, have a separate .tcl file you call with quartus_sh --t filename.tcl
    project_open <project_name>
    project_close
    This puts them in the .qsf and they will be used by the fitter.
