9 years agoQuartus Error (13066): Illegal directional connection from the pin (inout)
Hello all, I've posted this question to VHDL board, please forgive me if you've seen it there. Just thought it could be Quartus related so repost it here again. I'm using Quartus 16 lite to c...
9 years ago --- Quote Start --- Ive deleted your duplicate post, double posting is not allowed. FPGAs only have tristates on the external pins. You cannot drive tri-states internally on the FPGA. hence the error. --- Quote End --- Hi, Tricky, Thanks a lot for your reply. I understand the FPGA can only drive tristate on the external pins and didn't mean to do it either. In the below code, I was trying to latch the data from pin to internal register and put the internal data to pin when OE is enabled. Please help point out my misunderstanding. Appreciate it. regards, Yu
Process (in_aclr, FT2232_clk)
begin
if in_aclr = '0' then
iBusData_IN <= (others => '0');
elsif rising_edge(FT2232_clk) then
iBusData_IN <= FT_DataBus;
end if;
end process;
FT_DataBus <= iBusData_OUT when nOE ='1' else (others => 'Z');
