14 years ago
Quartus can't find shared library
I just installed on a fresh install of the latest Debian.
I get:
quartus: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
So I do:
locate libpng12.so.0
/lib/libpng12.so.0
/lib/libpng12.so.0.44.0
I think these files would usually be in /var/lib?
Suggestions would be appreciated.
Marion
    I am using Debian 9.3 with Quartus 17.1. I had the libpng12 issue (Debian is using libpng16). I ended up building libpng.....
    git clone https://github.com/glennrp/libpng.git
    cd libpng/
    git checkout v1.2.59
    ./configure --prefix /usr/local
    make
    sudo make install
    If it still has issues, copy libpng12.so to /usr/lib/x86_64-linux-gnu/
    My /usr/lib/x86_64-linux-gnu/ looks like this......
    ls -l libpng*
    libpng12.so -> libpng12.so.0.59.0
    libpng12.so.0 -> libpng12.so.0.59.0
    libpng12.so.0.59.0
    libpng16.so.16 -> libpng16.so.16.28.0
    libpng16.so.16.28.0
    • HMedi2's avatar
      HMedi2
      This worked for me. i'm used debian 10 buster.
    --- Quote Start ---
    If you're on a 64 bits Linux, try "export QUARTUS_64BIT=1"
    Alex
    --- Quote End ---
    Great reply, this worked for me :-D
    - Using Debian 64bit and Quartus 13.1
    Hi Marion,
    --- Quote Start ---
    rut/home/mr/Downloads\:ls
    11.1sp2_259_quartus_free_linux 11.1sp2_259_quartus_free_linux.sh
    rut/home/mr/Downloads\:./11*.sh
    Creating directory 11.1sp2_259_quartus_free_linux
    Verifying archive integrity... All good.
    Uncompressing Quartus II Web Edition (Free)...................................................................................................................................................................................................
    ./setup: 1: Syntax error: "&" unexpected
    --- Quote End ---
    Solution# 1: Stop using Ubuntu. Its not supported by Altera, and if you have any problems with the tools, you're unlikely to get help. Just install Centos 6.2 and everything will work correctly.
    Solution# 2: Ok, so you want to keep using Ubuntu. Even though you get an error, the archive was unzipped ok, so the next step is to:
    cd 11.1sp2_259_quartus_free_linux
    sudo /bin/bash ./setup
    and follow the GUI prompts. You may however get additional library library errors because Ubuntu is not supported.
    Cheers,
    Dave
    Alex
    Thanks again for the prompt response.
    Unfortunately, I have still not been able to get it to work.
    I did read the installation guide and learned that I should have put the ..quartus/bin
    directory in my path. So I did that, but it still didn't work. I don't think that was the problem, though.
    Next I deleted the whole /alt directory with the idea of going for the default location,
    but when I tried to install that way, I got:
    Thanks again for any suggestions.
    Marion
    Sorry, that was supposed to be QUARTUS_ROOTDIR_OVERRIDE (two r's in override), and it looks like in your case it should be set to /alt/quartus, ie it should be able to be started with ${QUARTUS_ROOTDIR_OVERRIDE}/bin/quartus
    Thanks for your prompt reply.
    I think I have set up the variables as you suggested, but no joy.
    ~:echo $QUARTUS_ROOTDIR_OVERIDE
    /alt
    ~:echo $LD_LIBRARY_PATH
    /lib
    ~:/alt/quartus/bin/quartus
    rut/lib\:ll *png*
    lrwxrwxrwx 1 root root 18 Feb 24 08:45 libpng12.so.0 -> libpng12.so.0.44.0
    -rwxrwxrwx 1 root root 155360 Feb 15 10:09 libpng12.so.0.44.0
    I guess I should have accepted the default location?
    Thanks again for your help.
    Marion
    Make sure the QUARTUS_ROOTDIR_OVERIDE environment variable is set to the location of your Quartus installation. Try adding /lib to your LD_LIBRARY_PATH environment variable. Try running ldconfig.
