19 years agoQuartus 7.1 Sp1 and DSPBuilder 7.1Sp1
Hallo everyone, I have a problem with my Installation. I have installed Quartus 7.1 Sp1 and DSPBuilder 7.1Sp1. If I want compile any Example Model like "singen" an error occured. The...
18 years agoHello, I have quite similar problems with DSP Builder...
I have Windows XP + Matlab R2007a installed + Quartus II 7.2sp2 Web Edition + DSP Builder 7.2. I've installed this dbg_x86_6.5.3.8.exe from http://www.microsoft.com/whdc/devtoo...nstallx86.mspx. Before this installation when I typed "java.lang.System.load('d:\quartus\quartus\dsp_builder\bin\PortManager.dll') " then I was getting the same error as Factsarescarce. After installation dbg_x86_6.5.3.8.exe when I type "java.lang.System.load('d:\quartus\quartus\dsp_builder\bin\PortManager.dll') " Matlab is freezed, status changes to Busy and there is no response from Matlab and i must shut it down from process manager. When I open an example project from DSP Builder directory (singen.mdl), click on Signal Complier and click Compile it runs but after a while it stops at this point... http://www3.speedyshare.com/data/295207951/9660288/20451456/signalcompiler.jpg and again I must shut Matlab down from process manager... When I run Dependency Walker the result was as in screen http://www3.speedyshare.com/data/247563530/9660326/56727428/dependency.jpg I don't know what is wrong...Matlab is installed without option "read-only", envirnoment variable QUARTUS_ROOT is set to d:\quartus\quartus (DSP Builder is installed in D:\quartus\quartus\dsp_builder). Maybe You have some suggestions? You think that it isn't a problem with DSP Builder but the problem is in my system? Thanks in advance.
