10 years ago
Quartus 15.1 and Quartus 16.0 Not Responding
Whenever I'm compiling my design on Quartus 15.1 or Quartus 16.0, the Quartus becomes not responding and I've to end the quartus process. I'm using Altera Max10 family device 10M50DAF484C6GES and my computer has 8GB of RAM which I think is enough to run any device. I have compiled the design earlier and it worked. Also note that I've also cleared any metadata folders from my project. Can anyone please help me resolve this issue ?
    Thanks for your response. Yeah I've tried compiling a simple project but no luck, same thing is happening. Do you know any sort of solution to this issue ? I've also raised an issue regarding this to Altera's site and they have asked me to run two commands in cmd prompt but even after running those two commands no luck.
    Are you sure that no hidden window has pop up waiting for you click there ?
    Did yoy try re-compile some existing project made for these versions to check if the problem persists ?
