16 years agoquartus 10 wont generate sof file
Hi everybody, I have a serious problem concerning generating sof file using Quartus 10. I am using a DE2 BOARD(CYCLONE EP2C35 ) and when I compile my project everything is fine, but it wont gen...
16 years agoDo you get the project to compile completely with no errors but simply don't have the SOF file? Are you sure you are running the web edition version? It may getting confused about the licenses... it might be confused and think you would rather have the 30 day license of the full feature active versus the web edition.
If you have access to another PC I would try installing the web edition on a clean PC. If that works then you know you have a licensing issue. if that does not work then you have another issue. If you want a second opinion, you can archive your design and post it and see if someone else can generate a sof. David
