13 years agoQsys usage for dynamic reconfiguration in StratixV
Hi all, I need to implement a transceiver configuration in Stratix V where i need to switch between different data rates. Before I was working with a Cyclone IV where the Megafunctions for ...
13 years agoBy the way, if you are trying an664 example, I think there is a problem with the external slave interface and that mistake doesn't allowed you to load the design to the board. You should create your own external slave in qsys.
