15 years agoQsys poor fmax peformance
Hi, I just want to know if somebody has experienced the same issue. I took an old SOPC Bulider design, compiled with Q8.1 for a EP3C25F256C8 device and used Q11 to convert it to Qsys. As SOPC b...
15 years agoDo you have a lot of fan in/out in your system? (i.e. a master connected to a lot of slaves or a slave connected to a lot of masters). If so you might want to change your topology a bit using bridges (and hierarchy).
Also are you constraining your design? If not then I wouldn't put too much faith in Fmax numbers even if it appears that the system works. I would look at the critical paths using Timequest to see where the longest paths are so that you know where to focus your efforts.
