13 years agoQII 12.1 Ubuntu 12.04 QSYS Avalon ALTPLL problem
In QSYS trying to add an Avalon ALTPLL module the operation fails.
The init windows pop up rapidly but the window to set parameters doesn't come up. QII 32bit or 64bit has same behavior. Other modules can be added normally. Where can i find error logs to look for the cause of the issue? QII MS Windows version works fine. Thanks, Michele.2 Replies
I have the same issue with Quartus II 12.1 SP.1 Windows 64-Bit and Cyclone V
[Update]
I didn't specified the device is Stratix V. Same behavior on 12.1sp1 and 13.0. The only way to use Avalon ALTPLL is change family to Stratix IV, add the module, switch back to Stratix V and generate! --- Quote Start --- In QSYS trying to add an Avalon ALTPLL module the operation fails. The init windows pop up rapidly but the window to set parameters doesn't come up. QII 32bit or 64bit has same behavior. Other modules can be added normally. Where can i find error logs to look for the cause of the issue? QII MS Windows version works fine. Thanks, Michele. --- Quote End ---
