15 years agopuzzling VHDL errors
Me and my team have been working on this VHDL code for about three days and need a fresh pair of eyes to look at it. we have error code (10500) : VHDL syntax error at Vhdl1.vhd(61) near text "COMBINE"; expexcting "case"
here's the VHDL code: LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY VHDL IS PORT( clk:IN STD_LOGIC; inputs:IN STD_LOGIC_VECTOR (2 downto 0); output: OUT STD_LOGIC (2 downto 0)); END VHDL; ARCHITECTURE vending OF VHDL IS TYPE STATE_TYPE IS (empty, fivecent, tencent, ready, change); SIGNAL current_state, next_state: STATE_TYPE; BEGIN COMBINE: PROCESS(inputs) BEGIN CASE current_state IS WHEN empty => IF inputs="00" THEN next_state <=empty; output <= "000"; ELSIF inputs= "01" THEN next_state <=fivecent; output <="000"; ELSIF inputs= "10" THEN next_state <=tencent; output <="000"; ELSIF inputs= "11" THEN next_state <=ready; output <="110"; END IF; CASE current_state IS WHEN fivecent => IF inputs= "00" THEN next_state <=fivecent; output <="000"; ELSIF inputs= "01" THEN next_state <=tencent; output <= "000"; ELSIF inputs= "10" THEN next_state <=ready; output <="100"; END IF; CASE current_state IS WHEN tencent=> IF inputs= "00" THEN next_state <=tencent; output <="000"; ELSIF inputs= "01" THEN next_state <=ready; output <= "100"; ELSIF inputs= "10" THEN next_state <=ready; output <= "101"; END IF; WHEN ready => next_state <=empty; output <="100"; WHEN change=> next_state <=empty; output <="110"; END CASE ; END COMBINE PROCESS ; SYN: PROCESS (clk) BEGIN IF clk'EVENT AND clk= "1" THEN current_state <= next_state; END IF; END PROCESS SYN; END vending;2 Replies
i don't think you need the second two instances of:
CASE current_state IS - Altera_Forum
the name of the file is VHDL
