15 years agopuzzled by the chapter of "LVDS Interface with the Use External PLL Option Enabled"
I am reading stx4_siv51008.pdf. I am puzzled by the chapter of "LVDS Interface with the Use External PLL Option Enabled". they discussed 3 signal "Serial clock ,Load enable , Parallel clock" whi...
15 years agoFitter Report -> PLL Usage, tells what each output does. You need to then correlate that back to the one you create.
