15 years agopuzzled by the chapter of "LVDS Interface with the Use External PLL Option Enabled"
I am reading stx4_siv51008.pdf. I am puzzled by the chapter of "LVDS Interface with the Use External PLL Option Enabled". they discussed 3 signal "Serial clock ,Load enable , Parallel clock" whi...
15 years ago"It's a pain. What I've done in the past is make it with the PLL enabled, then copy the settings"
But where did I find these setting if I want to copy. In which file , in which folder? THanks.
