13 years agoPseudo-random Number Generator
I have looking for a Pseudo-random number generator with some maximum linit. I know the LFSR approach but I dont know how to limit the maximum number generated by the LFSR. For example if I want to use an 8-bit LFSR with maximum limit of 200. How to limit the LFSR so that number must not exceed 200. Any link, idea or circuit will be highly appreciated Thanks Ali Umair12 Replies
--- Quote Start --- If the number is out of range, discard it and request another until you get one in range. --- Quote End --- This way an undefinite number of cycles is possibly required before you get a valid result. If you can't allow this, because you need the random number immediately, you must implement a different solution. If you don't bother the indipendence between successive pseudo-random numbers, you can simply feed the LFSR output to a modulo 200 adder: you sum the previous number to the LFSR result, divide by 200 and take the remainder, which is actually a pseudo random number uniformly distributed between 0 and 199. - Altera_Forum
You can't.
