13 years agoPseudo-random Number Generator
Hi, I have looking for a Pseudo-random number generator with some maximum linit. I know the LFSR approach but I dont know how to limit the maximum number generated by the LFSR. For example if I...
13 years ago --- Quote Start --- In theory, you need to change your lfsr_out to the range of 0 to 1 (1 not included) and then scale it by (limit + 1). In your 8-bit case: wire [15:0] temp = lfsr_out * 16'd201; wire [7:0] result = temp [15:8]; lfsr_out is the output of your LFSR and result is what you are looking for. --- Quote End --- This way you'll get a non uniform distribution, namely some values would be much more frequent than others, expecially if LFSR output range is not a lot bigger than the desired range. Extending the LFSR length would help improving the distribution.
