18 years agoPS Configuration with Commodity Flash
Hi All, Reading over the configuration documentation it is clear that the least significant bit of every byte must be transfered first during serial configuration. Commodity SPI flash devices, how...
18 years agoIf you want to stream the SPI flash output to FPGA in PS mode, then you have to perform the bitreversal during flash programming. Also Nexfflash/Winbond spiflash devices have been working as EPCS compatible replacement in the past, but I don' if they could be used with all Altera FPGA.
