15 years agoProgramming Harware
I'm an Altera newbie and am designing a board for a Cyclone III EP3C5E144I7N FPGA. I purchased a USB Blaster cable for configuration/programming. What typical hardware would need to be on the board t...
15 years agoThanks for the responses.
I plan on using the circuit shown in figure 9–30, programming serial configuration devices in-system using the jtag interface in the Cyclone III device manual. What should the MSEL pins be connected to using this circuit? Once the serial configuration device has been programmed in system through the FPGA, does the circuit then operate in an active serial configuration manner on subsequent power ups as the serial configuration device configures the FPGA? If so, Table 9-7 indicates a MSEL2=0, MSEL1=MSEL0=1 for my desired 2.5V supply and standard POR time. Aside from the circuitry differences, what operational differences exist between programming with the circuits shown in Figure 9-30 (Programming Serial Configuration Devices In-System Using the JTAG Interface) and Figure 9-7 (In-System Programming of Serial Configuration Devices?) What are the pros and cons of each and what would you recommend?
