19 years agoProgramming EPCS devices with JTAG
I was wondering whether this could be present in a design with the epcs_controller in a NIOSII/Avalon subsystem, but it would appear not, per this post in the nios forums: http://forum.niosforum.c...
15 years agoHi GIR,
You mentioned "There is an option in the serial flash loader interface to share the ASMI connection. This currently would require editing the Verilog or VHDL source for the Nios ASMI block and reconnecting it through the serial flash loader interface." How to edit ASMI block and reconnect it through serial flash loader? I have ASMI connections to EPCS.Int his case,how do I connect(instantiate) SFL? sfl_inst : SFL PORT MAP ( asdo_in => asmi_access_granted => dclk_in => ncso_in => noe_in => asmi_access_request => data0_out => );
