13 years agoprogramming cyclone IV with microcontroller
Hi this is franticAF and this is my first post. I'm working on board where an Altera Cyclone IV EP4CE6E22I7N is mounted (with attached flash memory EPCS4). A microcontroller is also present in ...
13 years ago --- Quote Start --- Again, if you can provide how the MCU is connected to the FPGA, I can help you better. --- Quote End --- the MCU is connected to FPGA through 16 I/O pin (8 bit address + 8 bit data) for internal register parallel read/write operations and also the SPI interface of micro is connected to FPGA. Others signals are not connected to MCU. DATA0,DCLK only from flash to FPGA. nConfig,nstatus,conf_done unconnected.
