15 years agoProgramming Cyclone III (EP3C16Q240C8N) on ARM board
Hi My interest is to know if someone have try to install Quartus II programmer on a ARM linux and if it worked? My second interest is to see the source code that do that. I have not see th...
15 years ago --- Quote Start --- However, even with that knowledge, you still cannot program your FPGA via JTAG, without the protocol for converting an .sof or .pof or .rbf file into a JTAG data stream. You could reverse engineer that using a logic analyzer though. --- Quote End --- You'll find part of the information documented with the Altera JRunner project. Another option is to to take a detour way over JAM STAPL code.
