15 years agoProgramming a flash device with the parallel flash loader
Hello I need to program a flash device using the parallel flash loader megafunction. The flash is not a configuration device, but is rather used to boot a processor up. The problem is that...
15 years agoThe objcopy utility can probably do that. It is part of the GNU toolchain, which is something that you may already have installed. In a cross-compiling toolchain the file name would normally begin with a target prefix, e.g. nios2-elf-objcopy or arm-eabi-objcopy etc. A bin to hex conversion is normally architecture-independent, so it doesn't really matter which toolchain to use.
I'm not sure if objcopy and Quartus II programmer speak the same .hex, but most likely they do.
