15 years agoProgrammable pull-up resistor in Cyclone II
Dear Sir, I've a question about the pull-up resistor. Suppose, the pull-up resistor is related to the I/O voltage Vccio and current strength, isn't it? Why does it show the resistor is a...
15 years agoDear FvM,
Do you mean the example is only more like a voltage shiffter? Can the pull-up resistor not be calculated in the same way as the example? Thank you! Peter
