15 years agoProgrammable pull-up resistor in Cyclone II
Dear Sir, I've a question about the pull-up resistor. Suppose, the pull-up resistor is related to the I/O voltage Vccio and current strength, isn't it? Why does it show the resistor is a...
15 years agoIn the device handbook, the minimum value for an external pull-up resistor is calculated. The internal pull-up resistor is in contrast a weak pull-up with a resistance several orders of magnitude above this minimum value.
