15 years agoProgrammable pull-up resistor in Cyclone II
Dear Sir, I've a question about the pull-up resistor. Suppose, the pull-up resistor is related to the I/O voltage Vccio and current strength, isn't it? Why does it show the resistor is a...
15 years agoDear Sir,
But I could see a similar example from the page of 8-3 to 8-5 in the MAXII Device Handbook, max2_mii5v1.pdf. It is for the REXT. It, however, is able to be used for an internal resistor, RINT, isn't it? Regards, Peter Chang:confused:
