10 years agoProgram Multiple FPGA
Can someone point me to an APP Note that describes how to compile multiple sof or pof files to generate a single file that can be used in Active serial mode to configure 3 FPGAs using the USB blaster...
10 years agohello.
> Which page corresponds to which FPGA? Page 0 - First FPGA? > In MY system PIN nCEO on FPGA 1 is connected to nCE on FPGA 2. yes you are right. I have done this before. you told us you have 3 pages, FPGA3's nCE is also connected to FPGA2's nCEO, right? if number of pages that are contained in pof file does not match with number of FPGA, your configuration will not done correctly. you can check that by probing conf_done pin of each FPGA. does it help you? bye if your circuit is connected like this document on page 258 https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
