18 years agoproblems with transmitter PLL input - Stratix II GX
Hi everybody, I am working on a custom board with a Stratix II GX (S2GX). I was asked to run the PRBS and serial loopback test in order to check the transceiver channels. I started my work fro...
18 years agoyes of course I have code from my colleague: full compilation returns no error, even if I try to change the ALT2GXB settings to obtain a datarate double of his (1600 vs 800 Mb/s)
My question was about understanding as much as possible the ALT2GXB settings and behaviour, not just who to trust. So the correct question should be the same I sent to support: "It is possible to obtain a rx datarate of 1600 Mb/s with a Stratix II GX, having available on board only a 40 Mhz clock? (and so feeding the RX section with a 80 Mhz clock, output of a FPGA PLL?)"
