13 years agoProblems with generating a flash file with elf2flash
I seem to be having issues using the Flash programmer to burn my elf and sof file into flash so it can boot from this location. I have a couple of questions. I have read and followed the documentat...
13 years agoI have additional information. When I use the above command and this is similar to the command used in the Flash Programmer, it generates a .flash file of size 32 bytes. If I change the command to the following, "elf3flash --input=ICETest.elf --output=ICETest.flash --base=0x0 --end=0x4000000", it generates a 157k ,flash file. I'm confused.
