18 years agoProblem with State Machine Editor
I have created a state machine using the SM Editor provided in the Quartus II software. My initial idea was to simply set two input values at static levels so that I could simply pass through a given sequence of states, stopping on an idle level at the end. When testing this using a very slow clock I noticed my outputs were not changing at all, though having programmed a specific set of values for each state. Note: The condition to change states is the same for all states. Would this cause the SM to simply jump all states until the idle condition is reached? Thanks. Andre1 Reply
If activation of the two inputs alternatively advances the SM by one step at a time, no uncontrolled transitions should occur. However, synchronisation of inputs to the SM clock domain is generally necessary. Without synchronisation, occasional, but very rare errors are expectable. Most likely not in a best, but when operating a real design.
