13 years agoproblem with size of sof file
I'm using quartus II, in my project I have a sof file of a size of 2412 Ko,
I don't even modificate anything in my quartus direcotry project and when I start assembler to generate a new sof file, I should have the same the same size for my new sof file, but I have a new sof file of 3459 Ko. So, I wanted to know why I have this problem, and if there is a way or an option that could make me generate a sof file with the wanted size ?12 Replies
I didn't change of version for quartus, the first assembly wasn't made
by me, but I use exactly the same settings as this first assembly. I need a smaller sof (top_fpga_opg_master.sof) because this one is implemented in cof file, with a memory map that is predefined, that I will convert in .jic. See the following attachment. - Altera_Forum
-First:
Have you changed something like the quartus version? The first assembly was made by you under the same settings and Quartus Version? -Second: Why is it so important for you to have a smaller sof? Is it responsible for anything to have a size of 2412KB?
