13 years agoproblem with size of sof file
I'm using quartus II, in my project I have a sof file of a size of 2412 Ko,
I don't even modificate anything in my quartus direcotry project and when I start assembler to generate a new sof file, I should have the same the same size for my new sof file, but I have a new sof file of 3459 Ko. So, I wanted to know why I have this problem, and if there is a way or an option that could make me generate a sof file with the wanted size ?12 Replies
you can select the EPCS64 in config device for the pof generation.
As for the jic, it is not used as not created automatically (I raised a request to Altera to allows this on a next release of Quartus). - Altera_Forum
Is it optionnal or compulsory ?
I just wanted to know if in assignements -> device -> device and pin options -> config -> config device I have to select EPCS64 or let the
Use config device in auto ? - Altera_Forum
problem was with auto device selected by the fitter, just had to select specific device
and choose in the list EP3C80 for cyclone III :p thanks - Altera_Forum
For more information I work on cyclone III, with the EPCS 64 flash,
my top_fpga_opg_master.sof is of type EP3C80 and my top_fpga_opg_horloge.sof is of type EP3C16 ; maybe I have to check one option that I would have forget in assignements -> Device or somewhere else ! Here is the attachment to show the options configured - Altera_Forum
yes I did it, I generated a new .jic file when I compressed my .sof file,
but unfortunately the new .jic file doesn't work :( - Altera_Forum
Did you enable compression in sof data properties?
Yes it was
Does it was made with the same version of quartus?
