13 years agoproblem with running hello_world in SBT
Hi; I'm new in altera, I have build a simple hello world project in nios software built tools, it was compiled and also downloaded into the cycloneIII board, but it wont be run and this errors will o...
13 years agothose kind of files should only be needed if you intend to flash your application, not if you just want to run it. How do you try to run your application? Did you set any flashing or programming options?
