13 years agoProblem with Quartus II (Web edition) RTL simulation with Modelsim (student edition)
I recently installed both Quartus and Modelsim. The problem is, i'm unable to simulate with modelsim. After relentlessly browsing the web, i figured i need to choose modelsim as my simulator and outp...
13 years agoIf you effectively installed it, the path is easy to find:
assuming you are using windows click Start click All Programs scroll to the folder named ModelSim or similar, click on it then right-click on the Modelsim executable and select 'Open File Location' from the pop-up menu, a WIndows Explorer Window will open. Right-click in the address-filed of that window explorer window and select Copy Address from the pop-up. Paste that in the appropriate place in Quartus' Assignments->Settings->Eda Tool Settings. I gather somebody else will help you with Linux, if that is what you are using.
