15 years agoProblem with JTAG
Hi everybody I've a problem with my MAXII I can't tranfert my program with quartus. When my CPLD is under 3V I measure an impedance of 10K on TDI and more than 1M for other between ground ...
15 years ago --- Quote Start --- "TMS: nothing" means, the pin is either shorted or the programmer connection broken. You have to fix this first. --- Quote End --- I try again to find what's going on this pin. --- Quote Start --- P.S.: Seems like the design lacks the suggested TCK pulldown resistor. --- Quote End --- I've read that altera device had intern weak pull up/down resistor and that was useless to add external resistor. But I'll try it too. Thanks for your help. I'll post when I've fix it (or not :cry:).
