13 years agoProblem with JTAG indirect
I am trying to configure a EPCS1 through JTAG indirect. I receive the following message, which is as cryptic as the help. [h=3]Serial Flash Loader Active Serial Memory Interface on device...
13 years ago --- Quote Start --- Just for those who may end up with the same error. The configuration all have weak pullup resistors, and I had 10K to ground for the nCE. Changed it to ten ohms and my problem disappeared. Wish they had better comments for there error messages. --- Quote End --- I doubt that the explanation is right. 10k pull-down is the Altera recommended value, and I have used it in many designs without problems. I also don't think that the dedicated nCE pin has a pull-up. If Altera didn't change the Cyclone chip (rather unlikely), there's probably a short to another I/O pin (with weak pull-up) in your design or a damaged nCE input.
