13 years agoProblem with JTAG indirect
I am trying to configure a EPCS1 through JTAG indirect. I receive the following message, which is as cryptic as the help. [h=3]Serial Flash Loader Active Serial Memory Interface on device...
13 years agoThe message might be cryptic if you have no ASMI instance in your design. The basic altserial_flash_loader has e.g. no access granted signal. But you didn't tell about the SFL ip used in your design.
You'll be always able to program the serial flash by loading the default Altera SFL image for your device instaed of your design.
