15 years agoproblem with cyclone POR
Hi! I'm using Cyclone I fpga. During reset my IO pins are not stable...their vibrating between '0' to tristate.. Is this normal? if so, I need a solution to keep my IO pins on tristate. can ...
15 years ago --- Quote Start --- It's an optional pin function, that takes effect after entering user mode. It's ignored before and during configuration read. --- Quote End --- Hey Frank, thanks for the correction. I was going to recommend he use the IO_PULLUP# option that is present on the Stratix devices to enable the weak pull-ups during configuration, however, the Cyclone device does not have that pin. I incorrectly assumed that DEV_OE performed a similar function (with respect to tri-stating during configuration). However, you're right, the device pins are tri-stated during configuration anyway, so the DEV_OE pin function is not required until after configuration. Cheers, Dave
