15 years agoproblem with cyclone POR
Hi! I'm using Cyclone I fpga. During reset my IO pins are not stable...their vibrating between '0' to tristate.. Is this normal? if so, I need a solution to keep my IO pins on tristate. can ...
15 years agothank you so much!
do you beleive this is the reason for the unstability I/O pins on the reset? how should I connect it so when the cyclone resets all pins will go tristate and only when the altera has done initialize all pins will go like programmed? 10x again!
