15 years agoproblem with cyclone POR
Hi! I'm using Cyclone I fpga. During reset my IO pins are not stable...their vibrating between '0' to tristate.. Is this normal? if so, I need a solution to keep my IO pins on tristate. can ...
15 years ago --- Quote Start --- I need a solution to keep my IO pins on tristate. --- Quote End --- The pin DEV_OE can be used to tri-state all pins. See p331 http://www.altera.com/literature/hb/cyc/cyc_c5v1.pdf Cheers, Dave
