15 years ago
Problem with --set=<argument=value> in case the value has spaces in between
Hi all,
I have a question, I am trying to set Timing optimization to extra effort for Quartus fitter through command line switches so I wrote
execute_module -tool fit -args {--set=optimize_timing="EXTRA EFFORT"}
But Quartus fitter errors out with
Error: Unknown argument "EFFORT". Refer to --help for legal arguments.
I face same problem with any option which accept values with spaces in between
I knew that this option can be set through QSF command but I need to set it through commandline switches
Any suggestions?
    I'm not saying do it in the .qsf, but to do it in your script:
    project_open proj_name
    set_global_assignment ...
    execute_module -tool fit...
    project_close
    I don't ever see args being passed directly to the command, but instead see it done the way I just mentioned.
    Hi Rysc,
    Yes, I knew that it can be set through "set_global_assignment" in .qsf file but, I want to pass it a quartus_fit executable through --set switch. I have no problem doing so with options which has no spaces in supported values, problems appeared with option values with spaces in between
    Abdelrahman
    You're in a script already? I've never done it this way but within a script just do something like:
    project_close
    That way all the assignments are the same format as the .qsf.
