13 years ago
problem on loading .jic file in epcs64
hi all,
i am using epcs64 flash in my design, and it is in as configuration. when i try to program the flash, for the first use the loading of image is success.and if i'am changing the image files or while loading the same file second time, it is showing the below mentioned errors.
"error (209062): flash loader ip not loaded on device 1""error (209012): operation failed"
suspecting that the flash is getting bad for the second time of programming.
waiting for your comments...please help me to find the cause of this problem.
thanks,
vinil.k
