15 years agoproblem of lpm_mux in megafunction
I wish to know the sel function in megafunction of lpm_mux , is it edge trigger or level trigger ??
13 years agoThere is little info on lpm_mux in lpm.pdf....
Is it possible to use lpm_mux in pipeline mode to demultiplex a stream of 16-bit data @ 100MHz into two stream of 8-bit data @ 50MHz ? Can lpm_mux on the first rising edge of the clock select the first 8-bits out of 16-bits and on the second rising edge of the clock select the second 8-bits out of 16-bits and so on? I suppose that in this case Sel is ignored by lpm_mux?
