18 years agoProblem about configuration using EPM7256AETC144 and AM29LV128M
I designed a PCB using StratixII devices(EP2S30F484C5),and the configuration scheme was FPP mode.When I downloaded the "config_controller_sratixII_dsp_top.pof" which was used in the "StratixII_DSP_Ki...
18 years agoHello,
the config_controller image shouldn't be specific to EP2S60. Altera is using "EP2S60" configuration controller also with other evalboards, e. g. Cyclone II Nios-board. But the flash image must be programmed separately by Nios II Flash Programmer with an image suitable for EP2ES30. Regards, Frank
