18 years agoProblem about configuration using EPM7256AETC144 and AM29LV128M
I designed a PCB using StratixII devices(EP2S30F484C5),and the configuration scheme was FPP mode.When I downloaded the "config_controller_sratixII_dsp_top.pof" which was used in the "StratixII_DSP_Ki...
18 years agoYou cannot use a .pof file for a EP2S60 on a EP2S30. If you have the source for the reference design, you may be able to modify the project to use the EP2S30 device and the pinout of your PCB to generate a correct pof file.
