15 years agoprinting floating point
Hi, is there any ways to print float number in Nios II? Example: a = 100, b = 195 c = (b-a)/100, so c = 0.95 so, how to print c = 0.95? because when i print, the answer is 0.
15 years agoUse a bigger memory.... The stack and heap assuming you assigned all the linker sections to the on-chip memory will be located at the end of the memory. If you don't have enough room to double the memory you could try using separate smaller memories and assigning the linker sections manually using the BSP Editor.
