15 years agoPower supply[PCB-dev.]-Cyclone IV
Hi. I have some questions regarding power supply for an Altera Cyclone IV. The FPGA will be powered by a li-ion battery (Vout is between 4,0 – 3,1). Since the battery could go below 3,3V m...
15 years ago --- Quote Start --- The image you show is not a good filter; the ferrite bead should have capacitors on either side to create a pi-filter --- Quote End --- . There are more capacitors connected as DE nano schematic shows. --- Quote Start --- My question is; how important is the isolation filter between VCCINT and VCCD and how should it be designed? --- Quote End --- Referring to your first question, not all Altera DevKits have a filter for VCCD_PLL, some are simply tying it VCCINT. Others are even using a separate analog voltage regulator for it. VCCA is the most critical supply node related to PLL operation, because it's supplying the VCO. PLL stability problems have been considerably reduced since Altera introduced a FPGA internal voltage regulator for the analog PLL supply. According to my experience, VCCD isn't critical for a standard PLL application not chasing for minimum PLL jitter. In so far, a common supply for VCCINT and VCCD can be acceptable with good bypassing.
