9 years agoPower saving techniques for FPGA
Hi, Can someone share experence about power saving in FPGA designs? I am facing power consumption and heat disipation problems. I tried disabling clocks but that gives very litle diference ...
9 years ago --- Quote Start --- It is not easy to optimize for power. Perhaps for a start you can check against the EPE to have an idea of static vs dynamic power distribution - just to estimate the potential reduction that can be done on the dynamic side. For static, if you device supports it, turn on the PowerPlay power optimization to normal/extra effort. Then, on the programmable power technology optimization, select the one that fits your design requirement. --- Quote End --- Can you provide any hint on where to start with EPE? I have never used it.
