18 years ago
power play question
what is the correct data to be entered to the power play estimator in this case:
im using 160 DQ lines that connect point to point to discrete DDR2 components.
i want to use OCT dynamic with calibration so ive entered:
SSTL-18,160 BI-DIRECTIONAL,5% TOGGLE,150MHZ AT DDR,OE = 50% & drive=series 50 ohm.
if i choose parallel 50 ohm also i get too musch dissipatin added and its not logical..
sould i need to choose parallel 50 ohm in that case?
does the SSTL class I already implements the termination?
ANYONE?
