15 years agoPower and ground pin decoupling capacitors
Hello everybody, In the Max II CPLD manual required Power and ground pin decoupling capacitors requirements are stated as follows: Board Decoupling Guidelines: Decoupling require...
15 years agoSo, did you say that I can use the IBIS or HSPICE to obtain the capacitance from a Quartus netlist, did you? Because the Quartus netlist is a .vo file so I think they don't support.
Do you know if I can set the Quartus to give me another kind of netlist file, like *.sp or *.spi file? These kind of files are supported by Nanosim tool. Thanks so much.
