15 years agoport array declaration error
Hi, I'm trying to declare an array in my port entity. I have read some about on the web but I get an array declaration error.
library ieee;
use ieee.std_logic_1164.all;
--use ieee.std_logic_...
15 years agoI make som changes:
package mytypes is
type data_ram_in is array(3 downto 0) of std_logic_vector (15 downto 0);
type data_ram_out is array(3 downto 0) of std_logic_vector (31 downto 0);
end package mytypes;
--library STD;
--use STD.textio.all;
--library altera;
--use altera.all;
--use work.all;
--use work.mytypes;
entity mult is
port(
clk :in std_logic;
reset :in std_logic;
-- aux : in array(3 downto 0) of std_logic_vector (15 downto 0);
mult_en :in std_logic
Data_a :in work.mytypes.data_ram_in;
-- Data_b :in work.mytypes.data_ram_in;
-- Data_out :in data_ram_out
end mult;
but now I have a strange error:
Info: Found 0 design units, including 0 entities, in source file bufer.vhd
Info: Found 2 design units, including 1 entities, in source file correlator.vhd
Info: Found design unit 1: Correlator-beh
Info: Found entity 1: Correlator
Error (10482): VHDL error at mult.vhd(37): object "std_logic" is used but not declared
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 270 megabytes
Error: Processing ended: Wed May 18 12:38:56 2011
Error: Elapsed time: 00:00:20
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings
What means std_logic is used but not declared??? I have the libraries, so I thinks must be something to do by my package, because if I don't used I don't have this error. Thanks again, Guillermo
