13 years agoPMA Direct Transceivers and ATX PLLs
Hey everyone, I've been digging through the documentation and trying things in Quartus and I'd like to see if anyone else has had success with this. Basically, I would like to use an ATX PLL t...
13 years ago --- Quote Start --- I did see the errata but the errors I'm seeing seem to be related to the difference in the clock settings between PMA direct transmitters and transmitters running in Basic mode. --- Quote End --- Ok. --- Quote Start --- I can use two CMU transceivers within one block of the ATX PLL in PMA direct xN mode and it works fine. If I add two adjacent transceivers on normal channels and put them in PMA direct mode just like the CMU transceivers, that also works. If I run the basic transceivers in basic mode along with CMU transceivers in PMA direct mode, it fails, even if I check the Use ATX pll box in the normal transceiver megafunction. --- Quote End --- You're taking a nice systematic approach to this :) I haven't tried to use the CMU transceivers since they would be too slow for my application. --- Quote Start --- I could have sworn I got it working before but I can't seem to get it to compile now. --- Quote End --- Perhaps you have changed Quartus versions since your last test? I just had a gnarly problem that Altera has yet to respond to (via an official SR): http://www.alteraforum.com/forum/showthread.php?t=39893 --- Quote Start --- Taking a closer look at the working CMU transceivers, the transmit clocks are coming from the ATX PLL and the receive clocks are coming from the PLL in bypass mode to drive the CDR. I wonder if this is just the graphic representation in the Chip Planner since the ATX PLL uses the xN clock lines. --- Quote End --- I haven't looked into the clock source in this much detail. However, I would expect the receiver CDR reference would be a direct route from whatever clock source you've chosen. When you configure the ALTGX you can select independent transmit and receive reference clocks, but if you enable the block for reconfiguration mode, those clock sources become a common signal. That implies the clocking is in fact common, and that the GUI is splitting them apart to make the visualization a little less mentally challenging. --- Quote Start --- I'll see if I can at least get both basic and PMA direct receivers to play nice. --- Quote End --- I have a couple of Stratix IV GX Development kits and a DE4. If there is something you want me to test, let me know ... Cheers, Dave
